Headlight Problems?
Old Sep 2, 2005 | 12:42 AM
DanielsDodge's Avatar
DanielsDodge
Default Headlight Problems?
I Just Replaced My Heads Lights Because All I Had were High Beams, and the low ones didnt work for some reason, so after i changed them the low beams still didnt work?, and after messing around with them they worked for a while, but now they dont work again i only have bright lights, can you tell me what is worng and what i have to do to fix it?
thanks
Old Sep 2, 2005 | 02:33 PM
richardmoore's Avatar
richardmoore
Default RE: Headlight Problems?
It sounds like you might have a loose wire somewhere, that would explain them going on and off while you were messing with them.
Old Sep 2, 2005 | 06:30 PM
Socha_62's Avatar
Socha_62
Sounds like a pain in the butt to find the problem. Like he said, probably a loose wire, but it could be somewhere under the hood, or even worse, somewhere inside your steering counsel. I would just keep looking around for other people that have had the same problem, if not your best bet is to take it to a car electrical specialist.
