heat issues
Old Oct 14, 2012 | 02:44 PM
98dodgedriver's Avatar
98dodgedriver
Default heat issues
I have a 98 dodge ram1500. I was having heat issues, at best all I could get was luke warm air. I went to a buddy's house to check it out as he is a good mechanic. We flushed the heater core, and burped the system to no avail then he noticed the a/c condenser was sweating, so we unplugged it and low and behold I had heat. He has no idea why the air was running at the same time as the heat, can anybody shed any light in that subject? Other wise I'll have to leave the condenser unplugged all winter and then plug it in again next spring, but I would rather the operating system be right.
Old Oct 14, 2012 | 03:11 PM
zman17's Avatar
zman17
Retired Moderator - RIP
A/C condensor? You mean compressor? If so, the compressor will cycle/turn on and off once in a while Normal . If it just keeps running constantly that's a problem.
Old Oct 14, 2012 | 03:23 PM
98dodgedriver
No, I was going to unplug the compressor, but the plug came off the condenser first. The a/c stopped running then the heat kicked up.
Old Oct 14, 2012 | 04:53 PM
zman17's Avatar
zman17
So when plugged in, does it run constant when on heat setting, or just cycle on and off ?
Old Oct 14, 2012 | 05:01 PM
98dodgedriver
We didn't check it while we we're there, but I would say it runs constantly because I've had the truck for three years now and have never had good heat in the winter, and when we unplugged the condenser the heat was hot enough to run me out of the truck on my way home. Do you have any ideas?
Old Oct 14, 2012 | 05:05 PM
zman17's Avatar
zman17
Plug it back in and see if it runs constantly. I'd like to know that first.
Old Oct 14, 2012 | 05:12 PM
newman1367's Avatar
newman1367
check the low side pressure switch, may be shorted.
Old Oct 14, 2012 | 05:36 PM
98dodgedriver
I plugged it back in and the air went back to luke warm, and it ran constantly, so I unplugged it again
98dodgedriver
where and what is a low side pressure switch?
Old Oct 14, 2012 | 06:03 PM
zman17's Avatar
zman17
I think I'd take the HVAC control module out (switch unit on dash) and check it out. Seems to me that something is wrong with the selector switch, at least that where I'd start.
