No power to A/C Clutch
Old Oct 21, 2012 | 12:56 PM
txrdstr's Avatar
txrdstr
Default No power to A/C Clutch
Let me start by saying sorry if a duplicate question, been reading for hours with no luck,
Last night did a Hughes plennum replacement, put it all back together and now the a/c clutch is not getting any power. it is plugged in, tested at plug with a dummy light. changed relay with a spare still nothing, is there a fuse I am not seeing? worked fine untill pulled it out of the way to do the plennum.
Thanks, Rod
Old Oct 21, 2012 | 03:09 PM
txrdstr's Avatar
txrdstr
PROBLEM SOLVED. went out for 4th time and looked it all over, found did not have low pressure switch connected, it was stuck down behind the a\c-alt bracket, so was able to loosen it enough to get the wire/plug, connected it upa nd amazing how stuff works when done right.
Old Oct 21, 2012 | 03:11 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Thanks for letting us know the fix to this prob.
