whenever i start my 98 up cold it will run perfect for about a minute... then it will run rough, the rpms dont drop but you can definately tell its not running right by the exhaust, then it goes back to running normal after about thirty seconds or if you give it a little gas and let it drop back to idle
i just replaced the idle air, i dont know about the throttle position sensor
generally speaking when one goes the other isnt to far behind it i had to do mine like a week apart from each other and so do most other rams ive noticed
