Plenum to-do list.
Old Oct 28, 2012 | 09:52 PM
muzz3256's Avatar
muzz3256
Me too. I think that NAPA had a few, but you had to make sure that you picked up the right size. as they come in a few different diameters.
Old Oct 28, 2012 | 09:55 PM
crazzywolfie's Avatar
crazzywolfie
Originally Posted by jconlin
the fans arent variable temperature, they kick on at 180 and theres no way to change it, but with this cooler weather now they dont run at all unless i idle for like five minutes
but you could get a adjustable switch for the fans so that they will not kick on unless it hits 190 or so which would allow it to run a bit warmer.
Old Oct 28, 2012 | 10:00 PM
jconlin's Avatar
jconlin
i could, thing is though they dont even run, i was running it pretty hard today up and down some hills hauling a bunch of crap in the bed and they never came on, i think it gets enough air through the radiator just going down the road
Old Oct 29, 2012 | 11:05 AM
gunbunny2bg4u's Avatar
gunbunny2bg4u
i love the title of your post.
Old Oct 29, 2012 | 08:11 PM
muzz3256's Avatar
muzz3256
So there's really nothing else I could/should do during the plenum job?
Old Oct 29, 2012 | 10:46 PM
merc225hp's Avatar
merc225hp
You could replace
Timing chain
Water pump
Lifters
Cam
Catalytic converter
Old Oct 29, 2012 | 10:50 PM
muzz3256's Avatar
muzz3256
So the timing chain and cover were done when I has a timing chain gasket leak. Are lifters hard to do and what kind of performance increase does it get me, if any? Or is it more of a preventive maintenance thing? I plan on doing the catalytic converter when I replace my exhaust in January, however it may meet a demise sooner, accidentally....
Old Oct 29, 2012 | 11:04 PM
merc225hp's Avatar
merc225hp
No increase whatsoever replacing the lifters, but you are right there and are ez to do so maintainance thing, around $110 for a set of Mopar performance ones.
Magnum roller lifters Mopar part number P5249862
