Bad problem???
Old Oct 31, 2012 | 06:24 PM
alljackedup01's Avatar
alljackedup01
Angry Bad problem???
Today i went out to go to work and my truck wouldent start it cranks and sputters.It all started a couple days ago i was driving home and the raidiator blew out on me so i put water in it and made it home and parked it and have been driving my dakota and i went out and it will not start now it ran fine before no problems at all... its getting fuel pressure i checked it and the plugs are getting wet it has an orange spark not blue the plugs are brownish in color i know the crank sensor is fine due to the tac when you crank it over so the asd relay is working the crank sensor is good cam sensor as well because they are linked the only thing i can think of would be the coil and the plugs idk this truck pisses me off any help would be appricated thank you
Old Oct 31, 2012 | 09:31 PM
dhvaughan's Avatar
dhvaughan
did it overheat bad?
any water (chocolate milk) in oil ?
does starting fluid down the throttle body help any?
does pressing the gas pedal to open the throttle plate help any?
