misfire issue
Old Nov 6, 2012 | 10:29 PM
a1m9x69's Avatar
a1m9x69
Default misfire issue
alright so i have a 99 1500 with a 318 and its having a misfire issue even tho i have put on a brand new cap,rotor,wires,plugs and coil on it any suggestions on why it might still be a misfire.
Old Nov 6, 2012 | 10:35 PM
kejobe's Avatar
kejobe
Try this:
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Old Nov 7, 2012 | 03:02 PM
97ramrod1500's Avatar
97ramrod1500
do you know which cylinder is misfiring? you could have a plugged or not working injector. you could also have low compression on a cylinder. You could do a cylinder compression test and if there is low compression on a cylinder then do a cylinder leakdown test. how many miles do you have on your truck?
Old Nov 7, 2012 | 03:03 PM
97ramrod1500
I also forgot to mention that if you didn't fix your plenum that may be the cause.
Old Nov 7, 2012 | 03:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1...... At least read the sticky and check it.
