Heater vent switch panel
Old Nov 6, 2012 | 11:38 PM
nskyline34's Avatar
nskyline34
Default Heater vent switch panel
Does anyone know where I can find a switch panel that will do in place of one of the center heater vents? I need three switches (at least). Or if anyone has mounted any switches any other place in their rig throw some pics up. I'm having trouble with where to mount them. (Wiring is the easy part....where to put switches...that's tough!)
Old Nov 7, 2012 | 03:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You can get a 3 gauge pillar pod. Like one of these for instance.
http://www.glowshiftdirect.com/Dodge-gauge-pods.aspx
Old Nov 8, 2012 | 12:55 PM
nskyline34's Avatar
nskyline34
I need switches, not gauges. Thank you though
Old Nov 8, 2012 | 02:41 PM
zman17's Avatar
zman17
You are right, sorry, read too fast. You need to make something custom in that case. Or maybe run the wires up to the overhead and install the switches there.
Old Nov 9, 2012 | 11:44 PM
OliverWalley's Avatar
OliverWalley
On my 94 Ram I have a spot just to the left of my overdrive switch where some type of switch or button could go if the original owner had purchased that option. Anyway, I needed a spot for two on/off illuminated switches for some extra lighting I was installing. I knocked out the plastic center of that square spot, which is exactly the same size as the aforementioned OD switch. My two new switches fit perfectly in that little square. I know you need three, but perhaps if you have the same dash setup as mine it might help you out. I can post pics tomorrow if you like.
