radiator, transmission oil cooler, ac condeser
Old Nov 8, 2012 | 09:49 PM
dondons1984's Avatar
dondons1984
Default radiator, transmission oil cooler, ac condeser
ok so here is bad luck.
I had my entire front end replaced a month ago. I then earlier this week hit a mule deer in which it ruined all in the title. I am now replacing all of them and need to know if I can drive it to a dealership to have recharged. I am using a couple used parts but not for my cooler I needed to replace. so does anyone here know of anything extra I can do? any extras?
Old Nov 9, 2012 | 06:48 AM
dhvaughan's Avatar
dhvaughan
as long as you are not leaking water, or transmission fluid, and those 2 are full and not overheating, then its fine to drive it.
DO COVER any OPEN ends of the lines, ports, openings, etc to keep out contamination. and of course, w/o a charge, don't try to run any of your heat/cool funtions that try to turn on AC, although it would trip out on low pressure anyway.
Old Nov 9, 2012 | 01:36 PM
dondons1984
ok thanks so much. I got everything off and gonna put it back on tomorrow since I work all day then I have to bend my bumper back into place also. any advice on that one? and I put plastic bags over all the openings to keep it clean so I hope that works.
Old Nov 9, 2012 | 11:34 PM
dhvaughan's Avatar
dhvaughan
new aftermarket bumpers can be bought pretty cheap on ebay. the cheap ones tend to be a little thin, but i don't think that matters.
if you want to straighten yours, consider a chain or strap and either a come-along or tree as a anchor. you can pull with the come-along in a controlled manner or just back away from the tree for a little less control. you can also beat on it with a hammer while you have tension on it.
to remove dents, you can remove the bumper and hammer on it from the backside.
