98 ram W/360 long crank time
for some reason for the last 4 months when ever i start my truck it will just keep cranking until I pump the gas pedal.The only codes i am getting are o2 sensor and speed sensor. the truck runs great other than the start up issue. on a side note while I have had this problem I have you used 2 separate fuel pumps.
does anyone have any ideas? sorry if this is in the wrong location or something i'm new.
Ok, could be the check valve in the fuel pump assy. When its cold try turning to key on like you gonna start it, then off about 3 times to prime it, should start up sooner. Another way to verify this is to get a fuel pressure gauge and see if the pressure drops after you turn off the truck
