Code 0455
Old Nov 16, 2012 | 11:56 PM
Blue Mopar01's Avatar
Blue Mopar01
Default Code 0455
My CEL came on and this code 0455: EVAP leak monitor large leak detected. Anyone else had this problem and how did you fix it?
Old Nov 17, 2012 | 08:01 AM
ryanmc's Avatar
ryanmc
im having the same trouble intermitten for awhile now, theres a lot of info on here about it. could be gas cap, leaking hose, leak detection pump or the canister.
https://dodgeforum.com/forum/2nd-gen...-leak-fix.html
im going to go double check all my hoses today, I did replace my gas cap with one from autozone but im not too confident with it.
Old Nov 17, 2012 | 09:07 AM
Blue Mopar01
I had the same code come up once and they said it was a gas cap that was loose. Mine was on good but the code was still there. My cousin went and flashed that code but now it came up again. Thanks for the link btw!
Old Nov 17, 2012 | 04:58 PM
gdstock's Avatar
gdstock
Only experience I have had on this was step-son's Taurus. Had to replace all the hoses to and from the canister and at engine on EVAP system. Hoses were deteriorated. No problem since then. Gas cap will do it as well if it is not sealing.
Old Nov 17, 2012 | 08:08 PM
wv ram's Avatar
wv ram
Smile code 0455
hi i had this issuse for about 2 years tryed all the fixes gas cap purge solienoid , finally took the evaporator canister down was all rusted on the mounting bracket hoses looked ok but i got a idea clean the mounting bracket painted it and took all the hoses loose , then took electrical tape and wrapped the hoses good put new clamps on and now going on 3 months [knock on wood ] my ce light has not come on , this is a very aggrevating problem seems this fixed mine , hope that helps , 01 ram 5.2 5spd 4x4
Old Nov 17, 2012 | 09:56 PM
Blue Mopar01
I'm goin out in the morning and looking over my hoses to make sure of their condition. Thanks for the info guys
Old Nov 17, 2012 | 10:40 PM
gdstock's Avatar
gdstock
Do not use regular hoses such as heater hose. Make sure it is rated for gasoline or it will get porous and fumes will seep through.
