Defrost - Compressor Cycle Time?
Old Nov 19, 2012 | 08:13 AM
Sooper's Avatar
Sooper
Default Defrost - Compressor Cycle Time?
I don't have a way to check the system pressure without taking it to a shop, and I don't want to do that unless there's something wrong.
When I have my heat and defrost on, the A/C compressor will engage, spin for 4 seconds, and release for 6 - 7 seconds, before the clutch engages again for another 4 seconds.
I know for A/C that's far too short and it means there's not enough pressure to keep the clutch engaged. Problem is, I don't know how long the compressor is supposed to be engaged during heat / defrost operation.
Any insight before I make an appointment to have the system leak checked and filled...for the winter.
Old Nov 19, 2012 | 11:58 AM
zman17's Avatar
zman17
Retired Moderator - RIP
It's normal. The ac cycle's to help with condensation and to keep the system oiled.
Old Nov 19, 2012 | 12:18 PM
Sooper's Avatar
Sooper
I knew the cycling was normal, but wasn't sure if a cycle that fast was a sign that the system is low on coolant. I remember when the system was low on coolant last summer, the compressor cycling was around 4 seconds like it is now.
Old Nov 19, 2012 | 06:35 PM
Go buy a r34 refill kit from walmart. They are like $30 and they come with a gauge so you can tell if it is low. Thats what I do anyways. Beats paying a shop to do it for me.
Old Nov 19, 2012 | 08:57 PM
Spillage's Avatar
Spillage
My shop does an A/C charge for $20.
Old Nov 19, 2012 | 09:16 PM
OK, if you can find a shop to recharge your AC for $20 then go for it. Shops I use charge a minimum 1 hour labor on top of supplies. Wish I was close to your shop.
Old Nov 19, 2012 | 10:44 PM
Sooper's Avatar
Sooper
Shops around here charge between $80 and $100, and that's if they don't charge a fee for just testing.
