Tranny swap issues- wrong year
Old Nov 19, 2012 | 04:02 PM
FfBill's Avatar
FfBill
Default Tranny swap issues- wrong year
I have a 97 ram 4x4 with a 5.9. I bought it as a project. The previous owner started to replace the trans. I am in the process of finishing it.
I went to plug in the wires for the tranny and the sensor plugs are different. Also I noticed there is another sensor in the tail end of the old trans but not the new one
The new trans bellhousing says 064-5. The original says 064-8.
I think the replacement trans is from a different year Ram
So does anybody know if I could do anything to make this tranny work or am I screwed?
Old Nov 19, 2012 | 05:21 PM
FfBill's Avatar
FfBill
Looks like the tranny is a little longer than the old one. But the transfer case bolted right to it
Old Nov 19, 2012 | 09:18 PM
QuadCabLuv's Avatar
QuadCabLuv
As long as they are both 46re's then you should be able to make it work. But if the new one is a 46rh then you will be screwed.
Old Nov 20, 2012 | 12:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1... Sounds like u got an RH instead of an RE. Even the wrong year RE will still have the same connector and plug right in. You just wouldn't have OD.
