coil spring upgrade
Old Nov 26, 2012 | 06:39 PM
madore33's Avatar
madore33
Default coil spring upgrade
hi there..i have a 1997 dodge ram 1500 4x4 reg cab short box..i was wondering what coil springs from what year diesel ram to put in the front to make it sit even.. if anyone has any suggestiions on part numbers brands etc..that would be greatly appreciated...thanks
Old Nov 26, 2012 | 06:41 PM
Halojm's Avatar
Halojm
Coils from a 2500 will give you about 2" higher. Might be cheaper to get a leveling kit, rather than new springs.
Old Nov 27, 2012 | 03:11 PM
Wombat Ranger's Avatar
Wombat Ranger
I think with the 2nd gen diesel springs people are actually seeing 3" of lift, while the v8 2500 springs are more in the 2" area.
Old Mar 6, 2013 | 12:36 PM
madore33's Avatar
madore33
so i should get the 2500 reg cab springs...or the ext cab springs..also the diesel springs or the 5.9 gas springs from the 2500....thanks
Old Mar 6, 2013 | 12:49 PM
merc225hp's Avatar
merc225hp
Lift will depend on how much your currant springs have sagged over the years. For spring info go here. http://dodgeram.org/tech/specs/springs.htm
Old Mar 7, 2013 | 01:57 PM
Nsmitty21's Avatar
Nsmitty21
Is there any advantage of a coil spring upgrade vs a level kit? Is the ride much rougher? I am also thinking about doing this.
Old Mar 7, 2013 | 02:30 PM
zman17's Avatar
zman17
Retired Moderator - RIP
PM RedneckRam, or maybe he'll chime in. He has done this to his truck.
