rear differential ram 1500 5.2 original?
Old Nov 28, 2012 | 09:37 AM
jjpanadero's Avatar
jjpanadero
Thanks for your opinions:
If I need to know is, if I can put a complete rear axle of a Ram 6 cyl to a
Ram 8 Cyl.
Scuseme for my bad Inglés.
Greetings.
Old Nov 28, 2012 | 10:22 AM
mantisman51's Avatar
mantisman51
A 94 Ram 9.25" axle can be directly swapped from a V8 to a V6 model, as long as they are from the same "era" of Ram. I think the 94-96 had a different ABS sensor and location, but then the 97-01 are the same, I believe. I'm sure someone more knowledgeable will confirm or dispel this. But I am 80% sure. Simply look at the transplant axle to see if the ABS sensor is on top of the differential. If it is in the same place as your current axle, it's all good.
Old Nov 28, 2012 | 10:26 AM
jjpanadero's Avatar
jjpanadero
Default Thanks Mantisman
So, i can put rear axle Ram 1500 1997-2001 6 cyl at Ram 1500 8 cyl 1994 and no problem?
Old Nov 28, 2012 | 10:30 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I think the wheel speed sensors are different on the earlier Rams. But you might be able to just swap the sensors.
Old Nov 28, 2012 | 11:25 AM
dlyter09's Avatar
dlyter09
Dodge Dude is right.. Hes the Grand master of funkkkk...
dodge dude94
^Duh.
Copy cat.
Old Nov 28, 2012 | 01:11 PM
dlyter09's Avatar
dlyter09
^Duh.
Copy cat.
Hey now I was just making sure it was said over again... That and I didnt really read over all the posts lol...
I corrected that post by the way...
