Factory Trailer Wiring Issue
Old Nov 28, 2012 | 07:39 PM
0ut1aw's Avatar
0ut1aw
Default Factory Trailer Wiring Issue
Hi all
Long time reader first time posting. I have searched but haven't come up with an answer.
I have a 1999 ram 1500 with factory trailer wiring harness. I use a 7 to 4 pin adapter and get a full functioning trailer (blinkers and stop) but no park lamps or running lights.
I checked every fuse and they are all good. The 7 pin connector is new. I should have power on pin 6 (opposite pin 1) on the square plug, I have no power.
The truck has trailer brakes added but I know nothing about the installation.
The truck is new to me.
Any ideas?
Old Nov 28, 2012 | 09:19 PM
gdstock's Avatar
gdstock
You have to swap a wire in some of the adapters. Check package.
Old Nov 28, 2012 | 10:51 PM
0ut1aw's Avatar
0ut1aw
There aren't any wires coming into the 7 pin with power while just the lights are on. Turn on the blinkers or stop lights and you get power on various pins but nothing with just headlights/park lights
Old Dec 4, 2012 | 09:23 PM
0ut1aw's Avatar
0ut1aw
Default Resolution.....
It seems that the big square relay/fuse under the hood marked trailer was partially blown. This makes no sense to me but all the light were working except the tail lights.
For kicks I swapped out the fuse/relay described above and now all is working well
hope this helps somebody
