Will this Steel Bumper work with a winch.? Iron Cross Road Armor
Thanks so much for the compliments ! This turned into about a month long project in evenings and on weekends. Had to cut my own brackets because of the body lift, and rearrange the winch clutch handle, rewire fog lights make fog/driving light brackets. Etc. makes it all worth it to get the kind compliments in the end! Thanks again!
I had to use flat steel 3/16"thickness to reinforce where the winch is mounted then grade 8 3/8 bolts to mount the winch. The WARN 8000 clutch handle was protruding above the winch, which would have it jabbed into the AC condenser/radiator. That was going to force me to have to extend the bumper out leaving a huge gap between the body and bumper, which would have looked " rigged /ghetto "" to me. I read on another off road forum where folks would adjust the winch clutch handle to face up when the winch is mount on it's side. After doing this mod, I was able to mount the bumper almost flush with the body with maybe a 1/2 " or 1/4" gap from the body. The reason for this is to leave a small clearance for the winch to solenoid cables so theses would not touch the AC Condenser causing a short when powered on. i had to fab. brackets from half inch steel and then grade 8 bolted and welded where possible. This bumper is " Rock Solid " on the Ram. I Have seen rams in the photo section that have white bumpers and they look pretty sharp.. From a cosmetic standpoint the black bumper just looks like something is missing from the Ram at a distance, but NO BIG DEAL. the lights are LED projector lights that are bright as He77, so kind of worried if I may have to downgrade to a lower wattage LED to keep from blinding oncoming traffic. The outer LED lights come on in place of factory fogs, and the middle LED lights come on with the high beams. If I go white I had contemplated using the wonderful stuff plasti-dip to try the look. This stuff is durable yet reversible if the look does not work. I will try to get more oics as soon as i can.
Thanks for all the positive comments again!
This is what I am debating doing. This IS NOT the same make of bumper I have, this one looks bigger, bulkier thank mine, but gives an idea of a white winch bumper.
Trying to get opinions to keep my winch bumper black, or chance to white.
Got this photo from the photo section of the forum.
