bypassing evap canister
Hello all, Diving into vac leak issues and found that one of the vac lines (don't know which one yet) has been broken off at the evap canister. My question is should I plug both vac lines and bypass the evap canister or should I close the loop to the canister by connecting the vac hose from purge solenoid to the TB? Just don't want to throw any codes. Keep in mind this is coming from someone who prefers a gutted cat aka not worried about emmisions! I just want to make sure I don't have a vacuum leak.
mine is a little different. it's more of a circular canister with two small vac line connectors completing the loop from the manifold and throttle body and one line going to fuel tank to subtract the vapors. One of the vac lines going to engine compartment is busted right at the canister. I do need to reconnect it correctly as I've got a pc of tygon tubing ziptied together to connect right now. I'm sure that still leaks and possibly another leak somewhere cause i still got wild vents. Checked one of the two check valves in that loop and found out someone put the check valve (that is not working now) on the wrong set of vac lines. I'm going to replace both check valves, put them in the right place and hopefully get a new connector for the evap canister tommorow if I can find one. Then maybe my vacuum leak will be fixed. if not I'll head over to cruise control module and see if it's causing a leak. Great thing about a beater is that you get learn a little something to be dangerous!
