tune up?
Old Dec 14, 2012 | 11:30 AM
simple jack's Avatar
simple jack
Default tune up?
my truck seems to "sputter and cough" every so often. its like its choking or something. i can hammer down and it stops. it doesnt stall but sitting at a light the rpms drop low. could it only be a tune up or maybe even only need plugs?
Old Dec 14, 2012 | 11:34 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
The IAC in the throttle body needs to be cleaned.
Old Dec 14, 2012 | 11:46 AM
simple jack
how hard is that to do? i know VERY little, if that much, about mechanic work. besides changing the oil and putting gas in it, i dont know much else. basic basic basic.
Old Dec 14, 2012 | 11:55 AM
dodge dude94
Not very. It's on the backside of the throttle body. So remove the air box, disconnect the wire going to it, take the two torx bolts out, pull it out. Pretty easy if you can get to it. Then take throttle body cleaner (I use that because it is a very quick solvent) and a wire brush and scrub the crap out of it, just make sure you don't pull, turn, or push in the plunger thing. It will break otherwise. lol
Old Dec 14, 2012 | 11:56 AM
simple jack
i havent put (i dont know exactly) that many miles on it since the last tune up. i try not to drive it alot due to gas mileage and gas prices
Old Dec 14, 2012 | 12:21 PM
dodge dude94
Tune ups are supposed to be done every 30k.
You likely need to clean the throttle body period. lol
Old Dec 14, 2012 | 12:33 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
There's no such thing as a tune-up on these trucks!
KIDS!
Old Dec 14, 2012 | 12:54 PM
dodge dude94
Whatever! It's the easiest way of saying: Replacing the plugs, wires, cap and rotor, and cleaning the Throttlebody.
Old Feb 9, 2013 | 04:36 PM
simple jack
ok, i just replaced the replaced the plenum gasket, pvc valve, and had my k&n air filter cleaned (along with some other stuff) because of running rough sometimes (and no check engine light). if its not an air problem, could it be a fuel problem (pump and/or filter)?
Old Feb 9, 2013 | 04:46 PM
stewie01's Avatar
stewie01
KIDS!
Pssh.. Old men
