Water Leak In Cab
Old Dec 24, 2012 | 09:49 PM
dodgeram07's Avatar
dodgeram07
I didn't read ****
3rd tail light and the rear window seal on 94-97 suck because the window sucks.. **** the top left and right of the seal where the roof line comes to together
belive me I pull and side out 2 times looking for it
Old Dec 25, 2012 | 10:27 AM
Spillage's Avatar
Spillage
Originally Posted by dodgeram07
I didn't read ****
Been there, done that... still have a leak
Old Dec 25, 2012 | 05:59 PM
brewman's Avatar
brewman
Had same problem. Ended up replacing the OEM rear window with a one-piece window and no more leaking.
Only way I was able to identify the leaking area was to remove all the interior panels and have someone stand in the bed with a hose spraying water on the windows and rear brake light.
Old Dec 25, 2012 | 09:38 PM
Bob5151's Avatar
Bob5151
I am going to focus more on the rear to start. I'll probably have to wait 'til the weekend to have time to look again. Thank you to all you guys, for the input. I'm going to update after the weekend with my findings.
Old Dec 26, 2012 | 07:03 PM
Spillage's Avatar
Spillage
Taking a close look at the back window;
I see the silicone sealant on the end cap of the track is cracked... it kind of looks like opening the passenger-side pane all the way has repeatedly knocked the end cap until the sealant broke and it has now moved out of the track by about 1/8".
So my guess is water coming between the panes (or into the track from the outside) is running out the end of the track, rather than the weep holes.
As the truck has aged, the back window has become harder to open, and does bump firmly at the end of its travel.
More silicone to be applied on the weekend, and we'll see if that does it... I'll clean the weep holes also.
Any suggestions for freeing up the travel (make the window panes less sticky)?
Old Dec 26, 2012 | 07:25 PM
Bob5151's Avatar
Bob5151
Well, I found the leak. It's pouring here tonight, and I went in the truck, and found the water coming in from the rear.
The truck has a sliding rear window, and as far as I can tell, there is a piece of hard weatherstripping that is broken/worn away. It's coming in from the driver side, running to the corner of the window track, and dripping down behind the rear seat and running onto the floor pan.
I'm glad I found it, hopefully I can fill in the area with clear silicone and stop it. I'm going to do it tomorrow, since I don't have my caulk gun at home. I will report back when I get that done.
Old Dec 28, 2012 | 08:26 AM
Bob5151's Avatar
Bob5151
I filled in the area with clear silicone today. Hopefully that will seal out water. At this point, I'm just waiting for it to rain again so I can see if that fixed it.
Old Dec 29, 2012 | 06:35 AM
97tn4x4's Avatar
97tn4x4
Mine leaks across the bottom, it runs down the track the panes are in and leaks out the corner.
Old Dec 29, 2012 | 06:47 AM
Bob5151's Avatar
Bob5151
That's exactly what mine is doing.
Old Dec 29, 2012 | 10:23 AM
Spillage's Avatar
Spillage
I'm suspect of this being the case for mine also.
