Antifreeze smell but not overheating
I come, yet again, asking for the expert advice of yall. Here lately, after the truck has been running and I stop and idle, the smell of antifreeze is pretty strong. I can only smell it around the fender well area. It isn't over heating, in fact it runs pretty cool. If there is a water leak, it isnt very big because the coolant level doesnt drop any. I have no clue as to what it can be. Any ideas?
If you have looked at the heater hoses, radiator hoses for leaks and found none then I would suspect the hose that runs from the intake to the water pump especially if it is still the stock one. A small leak there is hard to see and because of the location and the heat involved it may be burning off causing the smell and the lack of a puddle. Your coolant level will not drop at a fast level.
I had a similar issue. Ended up replacing the water pump, timing chain cover, thermostat, bypass hose.
All were leaking and burning off. There was a lot of corrosion where the leaks were, but no drips or visible leaks. The radiator level didn't drop either. I actually thought my heater core was hosed because the smell miigrated into the cab also.
You might also look at your freeze plugs.
I had to replace the radiator cap. Got a O'Reillys cap. Went bad shortly thereafter. Had to get a NAPA cap and no antifreeze smell since. But check the weep hole on the water pump.
