Stalling
Old Jan 13, 2013 | 01:24 AM
nacy369's Avatar
nacy369
Default Stalling
Truck stalls after acceleration (letting off the pedal), just completely dies or the rpms drop way down then kick back up.
Old Jan 13, 2013 | 02:01 AM
Matt Nickerson's Avatar
Matt Nickerson
Clean throttle body and iac. Check plenum. DIY for throttle body cleaning is in FAQ/DIY section
Old Jan 13, 2013 | 09:11 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
test battery and clean iac
Old Jan 14, 2013 | 12:02 PM
nacy369's Avatar
nacy369
Already cleaned throttle body and brand new battery, will look into iac.
Old Jan 14, 2013 | 06:31 PM
BlackRamSST's Avatar
BlackRamSST
I'd go with IACV as well. Or take the non mechanically inclined approach and rule it to be "water in the gas..." That was always my dads response to issues.
Old Jan 14, 2013 | 06:48 PM
brewman's Avatar
brewman
+1 on the IAC. Had similar stalling issues, and replacing the IAC fixed it. The IAC was $40 from autozone, and since mine was filthy and probably OE I went ahead and replaced it.
Old Jan 15, 2013 | 12:08 AM
gdstock's Avatar
gdstock
Make sure you reset PCM after changing.
