2001 2500 Ram & 2001 Durango swap
Old Jan 18, 2013 | 03:49 PM
BlackieLawless's Avatar
BlackieLawless
Question 2001 2500 Ram & 2001 Durango swap
So I think I got lucky & found a 2001 3/4 Ram w/a 5.9 (360), in decent shape for only $1500. All it needs is a transmission. I also have 1st dibs on a 5.9 engine w/ tranny & transfer case out of a 2001 Durango. I will also be getting the computer, wire harness, & torque controller out of the Durango as well for the $400, of course I am helping to pull it. While the Durango has 180K on it & the Ram only 114K, I suspect the Durango's engine was taken care of & is in better shape than the Ram's. Both trannys should be 4x4 46RE models and both are the same year magnum 360 engine.
My question as I am sure you can guess, can I just install the engine & tranny combo out of the Durango & bolt them in the Ram?
Also, I am thinking of getting some Summit shorty headers if I can swing it because I gotta believe they are easier to install outside of the truck. Maybe replace the plenum, wires, plugs, etc. as well IDK.
My second question, are there any other mods I will need to make like re-positioning sensors or should make during the swap?
Thanks all, Sean
Old Jan 18, 2013 | 05:38 PM
97tn4x4's Avatar
97tn4x4
Engine and trans should be the same but the t cases will be different. I would change the plenum, cap, wires etc while it's out. There'll never be a better time. On second thought I'm wanting to say the starters are on opposite sides. Ill have to look into that.
Old Jan 18, 2013 | 07:38 PM
BlackieLawless
97tn4x4, thanks for the tips. The info on the starter may be helpful too. I was curious if I would really need swap out the computer & wire harness I am at a loss for a reason I would need to. If I do & someone could explain why, I'd appreciate the insight. Given I am getting it anyway, I always can swap the computer but if I don't have to, is there a demand for them? Maybe I can get some of my money back. Maybe sell the transfer case too?
Zman, where are ya man? You are usually one of the first to set me straight whenever I post. lol
Old Jan 18, 2013 | 08:09 PM
97tn4x4's Avatar
97tn4x4
The harness and computer "should be the same" I just can't recall if it's the jeeps or durango's that have the starter on the opposite side or if it's both. Assuming the t case is in good shape you could prolly get most of your money back.
