Gutting cat Q
Old Jan 20, 2013 | 09:34 PM
KxRideRon125's Avatar
KxRideRon125
Default Gutting cat Q
i was thinking about gutting my cat..i got no clue if its clogged or anything just wanted it to be a lil louder, my real concern is if my mpg is gonna fall a $hi% ton an how much power increase will happen.
Old Jan 20, 2013 | 10:03 PM
Matt Nickerson's Avatar
Matt Nickerson
Gutting it will not affect mpg... You probably won't see much power increase unless its actually clogged
Old Jan 20, 2013 | 10:13 PM
oxymoron29's Avatar
oxymoron29
Please use the search function, there are threads about this 3x a week.
If it's a stock cat it's probably clogged. In the case that is is, mileage will go up, power increase will be fairly substantial, volume will go way up.
Old Jan 21, 2013 | 12:15 AM
greanbeans's Avatar
greanbeans
Just heat it up with a torch once you cut it open start truck and blow it out. Or just cut the thing off
Old Jan 21, 2013 | 12:18 AM
KxRideRon125
i know how to gut it im just kinda afraid to bc i dont want my mpg droppin alot, wats the best way to test it without using a pressure guage
Old Jan 21, 2013 | 08:47 AM
Use the search feature or read the plenum sticky to find your answer. This question is asked a dozen times a week
