no cat/engine light.
Old Jan 30, 2013 | 12:59 PM
moparmopar's Avatar
moparmopar
New Member
Default no cat/engine light.
Ok i have a 99 360, has a cat but its punched out for a 4 inch straight exhaust it dosnt happen very ofter but i throw the check engine light, knew i would by doing this and we dont have emissions test where i live so,
could i use an o2 sim or a non fouler???. would that stop the light and make my truck run the way it should.
Old Jan 30, 2013 | 01:05 PM
kejobe's Avatar
kejobe
Get two non-foulers (18mm) and drill one out. Install non-drilled into bung in exhaust. Install drilled one. Install O2 sensor. Shiuld be good.
Theres a DIY in the faq/diy section for more specific instructions.
Old Jan 31, 2013 | 01:09 AM
moparmopar's Avatar
moparmopar
New Member
Hey thanks alot did it and so far so good went pretty smooth.
