Just over heated ... Help
Old Jan 31, 2013 | 11:22 PM
MHell2k13's Avatar
MHell2k13
*farely new
Old Feb 1, 2013 | 06:20 AM
kejobe's Avatar
kejobe
You can get an antifreeze tester at Autozone or other parts store for cheap ($3-$5). Best to get one and check to see the mix. If it does freeze it can crack the block or something else. Water expanse when it freezes.
Old Feb 1, 2013 | 09:39 AM
gdstock's Avatar
gdstock
Originally Posted by MHell2k13
i live in illinois and it was about 0 degrees F. no it was overheating i popped the hood at home and i could hear it was hot. I think it might have frozen because when i re added my coolant my mixture might have been light on coolant so i will drain it and at like 75 coolant 25 water. would 0 degrees freeze the mixture? i know i felt warmth coming out of the t stat and through the upper radiator hose so i think that the t stat is fine if that makes sense.
So I was able to add a third of a gallon of antifreeze to the system. I started the truck up and it is now - 5 degrees f. It was sooo cold it took 6 min for the truck to get to just 150 degrees. The weird thing is at 150 I usually have heat but I didn't. Now the thermostat is rarely me ( 2 months) is it possible for a thermostat to freeze shut especially if I have a low mix of antifreeze?
Couple of things....75/25 provides less protection thatn 50/50 mix. So you need to get the mixture correct.
Yes, the water around the tstat can freeze, but even if stat doe not freez shut, ice prevents water form flowing to it.
Check HERE or another site for further info.
