E-Fan
Old Feb 7, 2013 | 03:22 PM
RageGuy's Avatar
RageGuy
Default E-Fan
I ordered an Electric Fan through Jegs, should recieve it in a few weeks.
I have heard this Mod boasts decent MPG gains, cant hurt with my current 10- 12mpg
Is there anything of note to watch out for, or be carful of when removing the stock fan/clutch? I plan to change my water pump also while I'm in there, or at least inspect it.
Old Feb 7, 2013 | 03:27 PM
petea216's Avatar
petea216
I run on in the place of the clutch fan on my 1984 Caprice. I noticed a slight increase in acceleration at WOT. That's about it. No MPG gains.
crazzywolfie's Avatar
crazzywolfie
i got better gas mileage with my mechanical fan install than i have so far with electric fan installed. which ones did you buy from jegs? you most likely payed too much since you didn't search here. there is some great electric fan info on here if you search for it.
Old Feb 7, 2013 | 03:30 PM
RageGuy's Avatar
RageGuy
Dont have the exact model with me but it was $111 shipped to Canada.
Really? That doesent make sence, removing the stock fan takes load off the engine, thus one would assume better fuel economy.
Old Feb 7, 2013 | 03:36 PM
colinbreckmang's Avatar
colinbreckmang
Post your MPG's increase I am very interested.
h3lzsn1p3r's Avatar
h3lzsn1p3r
no beter mpg cold because little drag on motor
when hot like with excesive highway driving it will give you .5 mpg mabey
Old Feb 7, 2013 | 03:40 PM
crazzywolfie
at $111 shipped to Canada i might be a bit worried about if they are big enough or pull enough air to keep your truck cool
i have not been able to match some of the gas mileage numbers i got with the mechanical fan installed. the only good thing is i only paid $30 for the fans at the local junk yard so it is not such a loss.
Old Feb 7, 2013 | 03:56 PM
gdstock's Avatar
gdstock
I did not notice any gain that I could identify with e-fan as I installed HS rockers and other things at the same time. But I am really happy that the engine temp does not rise when in stop and go traffic. Fan keeps it cool, in fact at the beginning, too cool. I had to experiment with the three programmed setting available on the controller.
Old Feb 7, 2013 | 03:57 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
with the older truck the altenator may be robbing the mpgs due to the incresed draw
Old Feb 7, 2013 | 04:28 PM
crazzywolfie
no. i pretty much never had to turn it on with the 160* thermostat installed.
