Tranny - First/Rev only after startup?
Old Feb 14, 2013 | 09:45 PM
gdstock's Avatar
gdstock
Yes, the check valve at the cooler. If you go the the FAQ/DIY section and search "check valve delete" there ara probably a coupld of threads with photos shoing how to do this.
Old Feb 19, 2013 | 09:24 PM
Aphasiac's Avatar
Aphasiac
Default Now leaking fluid from the bell housing when in reverse?
Now the truck has a pretty steady leak from the bell housing, but only when the truck is in reverse. Put it in drive, neutral or park, and it stops. What gives! :S
Old Feb 20, 2013 | 09:40 PM
gdstock's Avatar
gdstock
Recheck fluid level in neutral. May be overfilled.
