Trucks making clicking sound?!
Old Feb 17, 2013 | 08:47 PM
99ramrunner's Avatar
99ramrunner
Default Trucks making clicking sound?!
Ok so I had some idling/backfiring problems with finally got that fixed turns out it was the plenum gasket and the IAC valve. Anyway no it's running better but when I'm driving it it's making a clicking sound I thought it was the U-joints but the rear are all good and I just replace the front. So it makes a clicking sound as I drive it down the road it doesn't make it when it's in park just when I'm driving it, anyone know what it might be?
Old Feb 17, 2013 | 09:08 PM
gdstock's Avatar
gdstock
Where does it sound like it is coming from? What speed? Better or worse when turning?
Old Feb 17, 2013 | 11:21 PM
99ramrunner
I'm thinking tranny, from 10k right up to around 70k no it stays the same if im turning! I know the torque converter is going so would it be that by any chance? It
Old Feb 17, 2013 | 11:24 PM
gdstock's Avatar
gdstock
10K to 70K?
Check the bolts on flex plate to TC. Another member here had that experience. Remove inspection plate and may have to pull started. Pull spark plugs to make it easier to turn crank.
Old Feb 17, 2013 | 11:27 PM
99ramrunner
Ya You asked what speed and it make the noise when I'm going 10 kilometers to 70 kilometers an hour.
Old Feb 17, 2013 | 11:32 PM
99ramrunner
Originally Posted by gdstock
10K to 70K?
I tried that and they all seem fine! I used loctite when I bolted it together so they shouldn't come loose anytime soon
Old Feb 17, 2013 | 11:33 PM
gdstock's Avatar
gdstock
LOL! I was thinking RPM! Didn't think metric!
Had to look at pic of my speedo. So from about 5 to 40 mph. Cehck the TC bolts. How are your ujoints? I would check them as well.
Old Feb 17, 2013 | 11:43 PM
99ramrunner
Ok. I just rebuilt the whole front driveshaft and the rear is good. Could it be the ujoints in the front axle? Or maybe a bearing?
Old Feb 17, 2013 | 11:48 PM
gdstock's Avatar
gdstock
OK, if TC bolts are good, then it could be the u joints on front. Check front hub bearings as well. I suspect it may be clicking at higher speeds, but increase in engine and road noise may render it unable to be heard.
Would not hurt to double check u joints on deive shafts. Make sure bolts did not loosen off.
Old Feb 17, 2013 | 11:54 PM
99ramrunner
Ok I'll check all that tomorrow and see! Thanks for the tips and help!
