How can i test a 1998 Dodge Ram 1500 Power train Harness off the Engine
Old Feb 23, 2013 | 04:15 PM
This Dodge is for you's Avatar
Default How can i test a 1998 Dodge Ram 1500 Power train Harness off the Engine
Hey New to this forum, I have a 1998 Dodge Ram 1500 that sat for 4yrs and was attacked by ffffnn Squirrels, they ate the wires on my power train wire harness. I bought a harness on the net, however they sent my a an Automatic wire harness not a Manual harness. Needless to say the harness did not match up and as a second plan I spliced all the connections that were bad on the old harness from the good connections from the Auto- Harness. Luckily those connections matched up. Now I would like to test for continuity on the connections I spliced to be sure that the harness is good so I can rule that out if there is another prob.
I don't know how to use a Multimeter, and I don't know the right settings and procedure to test the connections. Can anyone help me with this ? what ever you can tell me is most appreciated.
Old Feb 23, 2013 | 05:14 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Then you are going to have serious issues with ANYTHING electrical. A multimeter is the most important fundamental tool. There are numerous sources searchable on the internet in the form of videos, discussion forums and blogs on electrical theory and how-to use about multimeters, scopes, etc. Knowing how to use one will open doors for you IF you are willing to learn.
There are multiple unknowns when dealing with a 20 foot 2' diameter mass of tiny wires wrapped in a plastic shell then wraped in friction tape. Too many variables to make it feasable to use any method other than a meter.
Old Feb 23, 2013 | 05:43 PM
gdstock's Avatar
gdstock
Getting the correct witining harness will signifiantly improve chanve of sucessful outcome. Rigged wiring is only inviting more problems down the road.
Old Feb 23, 2013 | 06:52 PM
dhvaughan's Avatar
dhvaughan
if you can splice wires with solder or butt connectors (not black tape), then you can learn to use a multimeter.
get a digital one from home depot, lowes, amazon, ebay or anywhere. a decent one will cost about $20-25.
test continuity using the OHMS setting. meter will read open or infinity when there is no continuity. put a probe on both ends of the wire. if continuity, the meter will read 0. if there is a resistor anything else in the way, it'll show a non-zero number for the amount of resistance. you are looking for 0.
all this assumes you know which wire is which at each end. if you don't, you can get a "tone" generator and probe. this is commonly used in phone, network, electrical work to trace wires.
good luck. i hate squirrels. the damn things started coming up out of the woods and getting on the deck, chewing on railings, stashing nuts under the lawnmower seat, etc. a brick of .22 shells has vastly reduced the bastards.
i have this model from home depot. its good enough.
http://www.homedepot.com/h_d1/N-25ec...1#.USlWoDdXDpE
