46RE problem
Old Mar 7, 2013 | 01:09 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by mr wendy
Thanks for all the advise..The truck is not a daily driver so I'll check it this weekend.How do I check the plenum there is a whistling sound during accelerating..
By removing the throttle body and looking inside the intake with a mirror and flashlight. I also suggest you read the plenum sticky on top of the forum.
Old Apr 21, 2013 | 11:11 PM
mr wendy's Avatar
mr wendy
Finally have an update..Checked the plugs looked OK but changed them anyway.
Checked the exhaust very weak pulled the cat it was plugged.Changed the cat checked the compression average 160 psi with 240k miles not bad..
Still need to check the plenum for leaks but the truck runs great now..Pulled a heavy trailer over the weekend no problem...
As for the Seafoam it works great.Had trouble a couple years ago with low compression on #6 cyl. with this same truck.Ran a can of Seafoam through the vacuum line on that side of the engine at around 1200 rpm and it clear right up. ( prob. what plugged the cat)
One more question though what kind of life span do injectors have.Should I check them or just replace them ?
Thanks for all your help...
Old Apr 21, 2013 | 11:15 PM
gdstock's Avatar
gdstock
Use a bottle of Techron in the gas to clean injectors. They should be fine. Cat clogs due to burning oil. Probably plenum gasket.
Old Apr 22, 2013 | 05:08 PM
zman17's Avatar
zman17
+1... Fix the plenum ASAP, you are going to ruin the new cat.
Old Apr 23, 2013 | 10:09 AM
mr wendy's Avatar
mr wendy
Ok....will do didn't realize the connection
Thanks...
