Oil leak
Old Mar 6, 2013 | 02:56 PM
ccd1977's Avatar
ccd1977
ok. I checked it out. Its defintely coolant! WTH?
Old Mar 6, 2013 | 03:05 PM
Sooper's Avatar
Sooper
Probably one of the freeze plugs on the back of the block. Might be a gasket, but unless you have coolant in your oil I doubt it's a gasket.
The bad news is that those leaking freeze plugs keep getting worse and worse, and their easiest to replace with the engine removed.
Old Mar 6, 2013 | 03:12 PM
ccd1977's Avatar
ccd1977
is there a freeze plug that I can use that will give me the longest time before replacing again?
Old Mar 6, 2013 | 03:38 PM
merc225hp's Avatar
merc225hp
You can get brass freeze plug kits.
Old Mar 6, 2013 | 03:53 PM
ccd1977's Avatar
ccd1977
Thank you! I will pick some up from Discount auto or autozone
