Starting Into New Speakers/Subs/Amps. Got Some Questions
Old Mar 20, 2013 | 09:19 AM
  #21
ChillyPhil's Avatar
ChillyPhil
Alright cool, i might look into getting the 6.5" ones then. How do you think they compare to the Kicker 5.25s though?
But yeah i have a Sony 52Wx4 channel headunit but I'm still going to hook up a Alpine 300W amp to run to all 4 of the speakers.
Old Mar 20, 2013 | 12:49 PM
  #22
beeker's Avatar
beeker
I don't recommend running those low powered Kickers, they only 150watts each, you will easily overpower those kickers with the amps you are looking at, look for minimum of 250watt RMS! And dual voice coil would be better. Make sure you get the right ohm subs, run at 1 or 2ohms when all wired up, that way amp is loudest. Running 4ohm load on many amps cuts power output in half.
Kenwood amps are good except the joy **** does not control amp gain(volume) it only controls freq bass boost. Volume can only be adjusted on the amp itself, and then on the head unit.
I'm running 2 Rockford Fosgate 10" P2S subs(low profile, 250w RMS each) in a JL Stealthbox, completely concealed under the rear bench seat. These subs are great, only thing is they took a long time to break in before they sounded good and boomy, about 1 year with low usage.
Also don't bother with the 4 channel amp at first if you on a budget, run the midrange off the deck, add amp later if you decide you still need it.
Old Mar 21, 2013 | 04:46 PM
  #23
ChillyPhil's Avatar
ChillyPhil
Well I actually found a nice deal I think I going to go with. A local guy is selling 2 10" Rockford Fosgate P1 subs with a Kennwood 700w amp and a plexiglass box. All for $120. I'll sell that box cause I need to get my custom box. Everything is in great shape besides the box is missing two plastic pieces or somethin? He said I could get them at walmart.
The subs are rated at 250w each but can handle up to 1000 he said.
What's everyone think? I been told not to buy used but this is a good deal and he'll even meet me at my house.
Old Mar 21, 2013 | 04:55 PM
  #24
ChillyPhil's Avatar
ChillyPhil
One picture.. He'll be sending more around 6.
Old Mar 21, 2013 | 07:31 PM
  #25
dhvaughan's Avatar
dhvaughan
i think either the speakers or the amp would be worth $120 each, so $120 for both seems like a pretty good deal.
how many channels is the amp?
Old Mar 21, 2013 | 08:16 PM
  #26
ChillyPhil's Avatar
ChillyPhil
I went ahead and bought it. Pretty good shape but needed wiped down because of the dirt and debris. And according to the Internet, it's a 2 channel.
But the subs are only rated 150w each and 300w peak according to the sticker on the subs.
Low quality pictures will be put up in abit.
Old Mar 21, 2013 | 08:27 PM
  #27
ChillyPhil's Avatar
ChillyPhil
Kennwood KAC7205 Amp
Old Mar 21, 2013 | 08:30 PM
  #28
ChillyPhil's Avatar
ChillyPhil
2 10" Rockford Fosgate P1 Subs
Old Mar 21, 2013 | 08:33 PM
  #29
ChillyPhil's Avatar
ChillyPhil
Tell me what you guys think or any tips. And here's what was missing from the box so where can I get them at? And how much do you guys think I could sell the box for?
Old Mar 22, 2013 | 09:02 AM
  #30
ChillyPhil's Avatar
ChillyPhil
Bump.
