Drive belt question
Old Mar 10, 2013 | 01:53 PM
1700 Rider's Avatar
1700 Rider
Default Drive belt question
I have a 2001 RAM 1500 with a 5.2 engine. My AC compressor crapped out and makes a lot of noise. I can live w/o AC but need my truck. The drive belt routing diagram shows the belt routing with and w/o AC, so I bought a belt for w/o AC and finally got it installed. It was difficult to put on and the tensioner is all the way towards the driver side. I checked stores for different pulleys for with and w/o AC and there doesn't seem to be a difference except I can't be sure about the crankshaft pulley. Is there a reason this belt is on so tight and is it to tight? Yes. I double checked and it is the right belt. It's a Drive Rite belt 885K7 made by Dayco. Thanks for any help and apologize if this is a repeat thread.
Old Mar 10, 2013 | 02:03 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Just get a belt thats a little longer.
Old Mar 10, 2013 | 02:17 PM
ReadRam's Avatar
ReadRam
you shouldn't need to change any pulley sizes....+1 longer belt.
Old Mar 10, 2013 | 02:20 PM
dhvaughan's Avatar
dhvaughan
its ok if the tensioner is all the way towards drivers side as long as the belt is not "too tight". the belt will stretch some over time.
Old Mar 10, 2013 | 02:33 PM
1700 Rider's Avatar
1700 Rider
I did the old fashion finger test I used to do on V belts on older vehicles where you tensioned by moving the alternator and there is some deflection that for those belts I would consider ok. Just not sure on serpentine belts.
Old Mar 10, 2013 | 04:52 PM
dhvaughan's Avatar
dhvaughan
tension concept/tightness/test is the same. the tensioner spring just does it automatically.
Old Mar 10, 2013 | 04:59 PM
zman17's Avatar
zman17
Hopefully there is a little play in the tensioner. It does not want to be tight up against it's travel towards the driver side. If so , I agree that the belt will stretch in time, but too tight is tight.
Old Mar 10, 2013 | 06:26 PM
caripple's Avatar
caripple
I have a 99 ram 5.2 and my AC clutch bearing went out when I was 200 miles from home. I tried the w/o AC belt but it was too short. Got a longer one to get me home.
DAYCO #5070900 also has # 7PK2285 on it and the box like thing it comes in. That go me home and I replaced the AC clutch with one from ebay about $100. I keep the DAYCO belt in truck as an emergency belt that will bypass the AC compressor. I understand the 85 in the second number is 85 inch length and the other numbers explain the number of ribs width an so on. I hope this helps you.
Old Mar 11, 2013 | 06:02 PM
1700 Rider's Avatar
1700 Rider
Thanks guys, There is a slight bit of play in the tensioner, but I think I will get the belt caripple used. The Autozone website says DAYCO #5070900 is a 90" belt. The one I have is 88.5 inches.
Old Mar 11, 2013 | 07:24 PM
Hahns5.2's Avatar
Hahns5.2
The non-AC bracket moves the idler pulley to a different spot than the AC bracket, so simply removing the AC compressor doesn't mean you can use the non-AC belt. You need a 89.5"-90.5" belt. Ask for a belt for a 2010 Tacoma 2.7L with AC to get a 7 rib 90" belt.
