Leveling kit question
Old Mar 14, 2013 | 02:53 AM
DodgeDodgeDodge's Avatar
DodgeDodgeDodge
Default Leveling kit question
Hello guys, I just installed my HBS 2.5" levelling kit on my 98 dodge 1500 4x4.
Love the look, gives it an aggressive stance, if I could figure out how to post pictures from my phone I would.
After the install I took it for a drive and there is a clunking sound that is new, everything got bolted up pretty tight. I will re-torque everything tomorrow I am just wondering if anyone else has a similar issue and if it is levelling kit related?
Just a note during the install, the sway bar on driver side popped out at the link. I got it back in and tightened it up.
Any ideas?
Old Mar 14, 2013 | 05:47 AM
kejobe's Avatar
kejobe
Could be the sway bar link that popped out. Or could be the shocks. The lower bolt needs to be TIGHT. IIRC, about 110 ft/lbs. The shocks are a common place for cluncking/knocking.
Since the end link popped out just replace it. Its no longer up to snuff.
Old Mar 14, 2013 | 08:59 AM
stewie01's Avatar
stewie01
Truck needs an alignment now too.
Old Mar 14, 2013 | 09:17 AM
DodgeDodgeDodge
Yes I will be replacing it soon. And I'll try tightening the shocks up some more, I certainly didn't get that kind of torque on it.
Old Mar 14, 2013 | 10:05 AM
petea216's Avatar
petea216
Also check the three nuts on the shock towers.
Old Mar 14, 2013 | 10:39 AM
DodgeDodgeDodge
Just put the truck back in the shop, going to tighten up everything up again, thanks guys let you know what I find out
