46rh temperature
Old Mar 26, 2013 | 07:01 PM
94Beater's Avatar
94Beater
Default 46rh temperature
A couple years ago now I got one of the 46rh Streel Evil transmissions.
Meanwhile I've installed 4.88 gears, rear locker and a mild lift on the truck.
Transmission seems fine, but I think it might be running little hot.
I know that it has to do a little more work (because of 4.88 gears), but I still think it gets too hot.
Without towing anything, cruising at 65 (maybe faster, still don't have right gear for the speedometer)in Over Drive tranny will get 200 deg +.
Could it be that my transmission temp sensor is too close to the fluid out-flow out of the tranny and the temperature I'm reading is as high as it would ever get. Cause it goes through the cooler next.
Or, possibly something with the TC not locking up in OD. Causing fluid to get hot.
When I turn off OD and keep speed lower and steady, transmission temp would drop a bit and stay steady around 180-190.
What is the optimum transmission temperature (or the range) it should operate in?
Old Mar 26, 2013 | 08:20 PM
dhvaughan's Avatar
dhvaughan
Ah, a Dr Evil transmission. I haven't heard that mentioned in a long time.
an old thread with good info.
https://dodgeforum.com/forum/2nd-gen...ml#post2831554
180 is real good.
i see your in AZ, so i guess its hot as hell out there. Have you got a big cooler on it? if not put on the biggest one you can find/afford.
if you can afford it, put on one of these.
Tru-Cool 4739-1 (LPD47391)
40,000 GVW rating, 45,000 BTU
page 2 of this thread...
https://dodgeforum.com/forum/2nd-gen...ter-added.html
Old Mar 27, 2013 | 04:08 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You want the temp sender right where you have it for the most accurate reading. The closer to where it comes out of tranny is best. This way you know right away if there is a problem and have time to shut it down. So I concur with DHV and what he suggested.
Old Mar 27, 2013 | 07:47 PM
dhvaughan's Avatar
dhvaughan
i don't know much about transmissions, but have read a lot about them. our transmissions suffer from poor cooling in overdrive, which is a big part of the reason that we're not supposed to ever tow anything in overdirive (thanks dodge).
there's a lot of aftermarket improvements available from sonnax and other parts makers. i don't know if any of those kits address the overdrive cooling or not, and/or whether Dr Evil includes those mods into his transmissions or not.
Old Mar 27, 2013 | 08:08 PM
dhvaughan's Avatar
dhvaughan
i googled Dr. Evil and came up with this funny story.
http://cl.acurazine.com/forums/showthread.php?t=487575
Old Mar 27, 2013 | 11:27 PM
gdstock's Avatar
gdstock
Red face
So the moral of the story - pick a shop with the latest diagnostic equipment. The IAC would have shown up as an issue......
