Found a wonderful antifreeze leak!
Old Mar 29, 2013 | 02:07 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
It could also be the hose.
When I had my plenum replaced, the hose was rotten and tore apart when it was removed from the t-stat.
Old Mar 30, 2013 | 11:38 AM
tylarkin's Avatar
tylarkin
if its coming from near the thermostat you should check the coolant temp sensor in the intake. mine was leaking around the plastic electrical connector on the top of the sensor
Old Mar 31, 2013 | 03:15 PM
Johnn123's Avatar
Johnn123
Will check but it was in pretty good shape when I took it off and reinstalled it.
That I will do for sure, hadnt even thought of that! Just waitin on my haynes manual before I attemp anything.
Old Mar 31, 2013 | 03:38 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You do know that you can download a free 2001 service manual from the FAQ/DIY section right? You should have both anyway, because one has some info or pics that the other one doesn't .
Old Mar 31, 2013 | 04:29 PM
Johnn123's Avatar
Johnn123
I knew they were there but not that they were downloadable! Good now i can see where the sensor is, thx again Zman!
Old Mar 31, 2013 | 04:31 PM
zman17's Avatar
zman17
The ECT is under the alternator. You can see it from the passenger side.
Old Mar 31, 2013 | 10:55 PM
Johnn123's Avatar
Johnn123
Ill remember that when i'm there, thanks again !
Old Mar 31, 2013 | 11:20 PM
crazzywolfie's Avatar
crazzywolfie
so you just used a gasket between the thermostat housing and the intake? no type of sealer? that may be were your problem is. i know i have never been able to get a good seal with just a thermostat gasket. they always seem to leak even if it is just a tiny bit. i started using rtv gasket maker stuff. haven't had a problem yet.
Old Apr 1, 2013 | 12:11 PM
Johnn123's Avatar
Johnn123
I did use a sealer wolfie, black gasket maker by permatex. Guess ill find out when I take it apart lol
Old Apr 1, 2013 | 04:30 PM
Sheriff420's Avatar
Sheriff420
My timing cover leak put coolant in the same place as the picture because the fan blew it back there. It was a slow leak.
