Remote transmission filter question
Old Mar 30, 2013 | 02:40 PM
muzz3256's Avatar
muzz3256
Default Remote transmission filter question
I'm looking at buying a remote transmission filter to install when I delete my check valve. I've had one transmission killed by a plugged check valve and don't wish to do that again. I'm looking at the Derale 13090 remote filter kit (http://www.lpiracing.com/Derale-Tran...838p183086.htm) and was wondering if this kit is sufficient or if I'll need to buy more parts. Also, is there a better kit?
Old Mar 30, 2013 | 03:48 PM
guzman's Avatar
guzman
Default Remote filter
That system should be all you need, there are more choices on ebay that have the IN and OUT coming out of the filter housing at a 90 degree rather than coming up out of the housing.
Old Mar 30, 2013 | 06:22 PM
moe7404's Avatar
moe7404
check this out. i have one on mine. it just fits in the cooler line. in the inlet fitting, i think its the rear one. easy to put in. have to remove some line. i think most mopars are 3/8 tubing, but check yours. its a cut/paste sorry
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com.au/magna-fine.html*
2. for other sizes wix 58964 5/16 tube size reff:http://www.wixfilters.com/filterlook...sionfilter.asp
Old Mar 31, 2013 | 04:53 PM
dhvaughan's Avatar
dhvaughan
+1 on getting one with 90* fittings.
https://dodgeforum.com/forum/2nd-gen...ter-added.html
