Engine quits only under load
Thank you so much for this explanation. I have a couple of books that discuss/explain modern computer controlled auto systems - but none of them have much discussion on what happens when this or that sensor fails to perform or the types of failures and the related symptoms. I suppose this would be asking a lot since there are so many variations. While I am crawling around and replacing things, I'll check the O2 sensors. Thanks again.
Sorry - I missed this yesterday. Actually, the first time this happened the truck sat for several hours but would still not start. Changed the coil - started right up. The 2nd time it sat overnight. I came back in the morning, tried to start it; it cranked but did not start. I changed the coil and away she went. The third time I changed the coil right away and was back on the road. I now have two god coils behind the driver's seat!
