Cylinder 6 misfire/transmission slipping help
Old Apr 5, 2013 | 03:53 AM
Cheertashie's Avatar
Cheertashie
Default Cylinder 6 misfire/transmission slipping help
I thought I saw a post about something similar a few weeks ago and now I can't find it. Sorry if its repeated, I just need help!
I have a 2001 dodge 1500 5.9 automatic and for the last few weeks, the transmission seems to be slipping when going from second to third intermittently. Originally the check engine light came on and said that I had a cylinder 6 misfire. I took it into get checked out and the spark plugs, wires, compression, etc. were all fine. They thought a fuel injector might have been clogged and they put cleaner in it, but that was just them "guessing". My truck still seemed to slip between 2nd and 3rd, took my truck into the dealership to get the transmission serviced and one of the bands was lose, they fixed that and said the transmission looked good. They truck seemed to be fine for a day and then started to slip again. So, I took my truck into another shop explaining my problem and they couldn't figure anything out either!
In the last 2 years, I've gotten a rebuilt transmission put in, a new computer system and a had to get my drive shaft replaced after it fell off while driving on the highway, I'm not having the best of luck
Old Apr 5, 2013 | 06:11 AM
redneck_ram's Avatar
redneck_ram
check out the transmission thread sticky at the top of the tech page. its a bit long, but its a worth while read!
Old Apr 5, 2013 | 01:16 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Is it slipping or just simply not shifting to 3rd?
Old Apr 5, 2013 | 03:34 PM
Cheertashie
It does shift to 3rd, but it slips about 20% of the time driving
Old Apr 5, 2013 | 04:09 PM
zman17's Avatar
zman17
Slipping or delayed shift? As in if you take your foot off the pedal does it shift then? Read this and see if you find anything similar. https://dodgeforum.com/forum/2nd-gen...agnostics.html
Old Apr 6, 2013 | 01:47 AM
Luca _The_Kunk's Avatar
Luca _The_Kunk
check your output speed sensor after a while they will get metal shavings all oer the magnetic end and cause the trans to go crazy clean it off good with a rag and pop it back in and see if it shifts out right
