Weak no power
Old Apr 8, 2013 | 10:57 AM
nelly3597's Avatar
nelly3597
Default Weak no power
I have a 2000 Ram 1500 5.9 gas, 4x4. I have had dual exhaust installed and a K/N Cold Air System, and running a Super Chip programmer. It runs good and sound Great but it has NO Power, Taking off from like a red light I get passed by kids on bikes, and even power braking it will not break the tires. traaveling down the road at 60 and you start up a hill it want pull even the smallest hill without kicking down in passing gear. HELP I have read about lots of things to check but I need to know WHERE DO I START???
Old Apr 8, 2013 | 11:02 AM
Welcome to DF. Start by reading this:
https://dodgeforum.com/forum/2nd-gen...new-topic.html
Then read this:
https://dodgeforum.com/forum/2nd-gen...um-thread.html
Thats most likely your problem.
Old Apr 8, 2013 | 12:39 PM
Ham Bone's Avatar
Ham Bone
Take the super chip out. And put the stock airhat back on.
For real though. Unscrew your upstream O2 sensor and take a test drive. If its a lot more powerful your cat is clogged. Which means your plenum is probably bad
Either way, check your plenum. It's probably bad anyway. Do you get any pinging? Codes?
Also overdrive is for flat land, so that's not a problem, just the way it is
Old Apr 8, 2013 | 01:03 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+2, the plenum is shot.
Old Apr 8, 2013 | 02:46 PM
nelly3597's Avatar
nelly3597
have noticed a little ping but seemed to stop with 91 oct. no codes
Old Apr 8, 2013 | 03:22 PM
zman17's Avatar
zman17
91 octane and no ping = blown plenum gasket. Seriously, read the plenum sticky. I know it's long, but you'll find out what you need to know.
