Speaker clearance issue
Old Apr 9, 2013 | 09:23 PM
mopar961's Avatar
mopar961
Default Speaker clearance issue
I just put in some kicker 6x9s in my truck. I had to put a 1 inch spacer for them to clear. Now they stick out to the point where the door panel barely fits on. Is there a way I can cut the trim where the grill is so I can have the speakers showing so I can have a better clearance. And I want to use original door panel. I don't want accustom fiberglass thing. Thanks in advanced!
Old Apr 9, 2013 | 09:28 PM
gdstock's Avatar
gdstock
I guess you can cut it out....its your truck! Don't understand why you put a 1" spacer, then ....didn't you expect a fitment problem when adding the spacer? Remove the spacer seems like the best way to solve it.
Of course photos may help provide some clarity.
Old Apr 9, 2013 | 09:34 PM
mopar961's Avatar
mopar961
No spacer would mean it would hit the window track. The spacer itself fits fine but I can't get the panel back on. How would you go about cutting it?
Old Apr 9, 2013 | 09:40 PM
mopar961's Avatar
mopar961
I know putting a spacer in might have made it bubble a little but I can't get the panel on. Is there like a video or even pictures I can see somewhere so I can get ideas. I've been googling and found pretty much nothing.
Old Apr 9, 2013 | 11:01 PM
dhvaughan's Avatar
dhvaughan
did the speakers come with grill/covers.
i can't believe i'd suggest this - but if you used a cutting tool and cut out the grill shape in the panel and let the panel lay flat around the speaker instead of being bulged up over it - then you could install the grill over the top of the hole in the panel. be very careful to know how much gap the grill would cover. 1/4"?. 3/8?. your hole would have to be that precise.
the other options are to live with it like it is
or - remove the kickers and return/swap them for something less deep.
i have a 1/4 inch spacer on my rockfords and its a liveable bulge.
here's what you already know.
https://dodgeforum.com/forum/audio-v...-speakers.html
