EGR Valve Replacement
Old Apr 11, 2013 | 01:18 AM
fcf14's Avatar
fcf14
Default EGR Valve Replacement
OK so I almost positive my egr valve is stuck closed, the exhaust smells weird, mild performance loss, and spark knock under load/high rpms. Anyone know the correct way to connect the vacuum hoses to it? 1995 5.9 360 btw
Thanks
Old Apr 11, 2013 | 01:52 AM
Hahns5.2's Avatar
Hahns5.2
There's probably a diagram under teh hood.
To see if the valve is working, apply vacuum directly to the valve while idling, if the valve opens, you'll know.
Old Apr 11, 2013 | 02:01 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
could be your plenum too
Old Apr 11, 2013 | 02:06 AM
fcf14's Avatar
fcf14
I just replaced the plenum so I know its not that, and I ill try directly applying vacuum to it, there is a diagram under the hood. but its not very helpful at alll lol
Old Apr 11, 2013 | 02:09 AM
dodge dude94
you could also just block it off...
Old Apr 11, 2013 | 04:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you also replace the o2 and at least had the cat checked, gutted, or replaced?
Old Apr 12, 2013 | 12:28 PM
fcf14's Avatar
fcf14
Yes i just gutted that cats and nothin changed and new 02 sensor, i got a new egr, just looks like its gonna be a pain to hook up and figure out which vacuum lines go where.
