Rebuild Magnum 360 Motor
Old Sep 1, 2013 | 06:00 PM
  #81
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Ok, i emptied the gas tank (and fuel line), put about 5 gallons of new gas in. I wired up the fuel pump until new gas started to come out of the line, then i hooked it back up to the fuel rail. Tried to start, and still no luck. It stil doesn't start. Any more suggestions?
Old Sep 2, 2013 | 11:35 AM
  #82
aofarrell2's Avatar
aofarrell2
Sorry if this was mentioned elsewhere, did you replace dizzy cap, rotor, wires, and plugs? I've got a lurking the plugs ain't gapped right. Too big of a gap. Pull em and double check and make sure they aint' fouled too bad.
Old Oct 15, 2013 | 08:35 PM
  #83
1997JollyGreenGiant
Got it running! All it took was someone turning the key while someone else turned the distributor. What a relief! Anyway, now to finish my brakes, put my radiator back in and a few more odds and ends and it can be on the road! Thanks for all of your help!
Old Dec 7, 2013 | 05:51 PM
  #84
snowboundrmk's Avatar
snowboundrmk
Do you have a video? I'm curious how it sounds with that cam.
