318 running rough cant track it down!!
Old Apr 23, 2013 | 03:58 PM
Crossmaster567's Avatar
Crossmaster567
I tested it again. Its putting out spark but possibly looks a little weak? And its more of a yellowish spark.
Old Apr 23, 2013 | 04:07 PM
Crossmaster567
I tested it again. Spark looks yellow and maybe a little week. Not much to compare it to.
Old Apr 23, 2013 | 04:09 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
If it looks yellow it IS weak. lol
Your coil might be dead there.
Old Apr 23, 2013 | 04:33 PM
Crossmaster567
Coil is brand new. OEM.
Old Apr 23, 2013 | 06:28 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Not wanting to read back in the thread, but check the coil wire itself too.
Old Apr 23, 2013 | 06:43 PM
Gaius's Avatar
Gaius
If you got it wet, pull the cap to see if there's moisture. Spray some WD40 and dry it to get rid of the water.
Old Apr 23, 2013 | 06:53 PM
zman17's Avatar
zman17
Now that I think of it, you should disconnect the negative battery cable, and pull every single plug you can find, clean,dry and use die electric grease on them. Underneath, like o2's and all tranny and diff sensors. Uptop, all. In between, there is also a plug / harness on the driver side behind the lower wheel well plastic insert.
Old Apr 23, 2013 | 07:39 PM
Crossmaster567
Went through the cap and rotor. Just recently done a tune up on it before this happened. So I should go through the harness?
Old Apr 23, 2013 | 07:43 PM
zman17's Avatar
zman17
Only if you want to troubleshoot and eliminate some possibles. And a tune up "before this happened " really means nothing now.
Old Apr 23, 2013 | 07:53 PM
Crossmaster567
Thanks. Ill be back on tomorrow with some more news!
