Stuck sensor
Old Apr 23, 2013 | 06:07 PM
Blue Mopar01's Avatar
Blue Mopar01
Exclamation Stuck sensor
I'm working on tearing apart my plenum and one sensor or connection to the a/c is stuck( the one that goes into the wiring harness w/ the injectors). I don't know what I'm doing wrong, I took out the red peice thinking that was holding it back and that didnt work. Any help?
Old Apr 23, 2013 | 06:19 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You have to look for a tab to either push or pull. The red thing just locks said tab.
Old Apr 23, 2013 | 06:22 PM
Blue Mopar01
K, I'm not finding much for a tab to pull or push. Not sure why the two halves won't pull apart. Lubricant wouldn't hurt them would it?
Old Apr 23, 2013 | 06:26 PM
zman17's Avatar
zman17
Not at this point, maybe the contacts are corroded together, and you just need to pull harder? The red thing is just a lock like I said. So look at the plug better before something bad happens.
Old Apr 23, 2013 | 06:39 PM
Blue Mopar01
Thanks zman, after a little persuasion the tab loosened up and the connection came apart. (points were a little corroded.) lol
Old Apr 23, 2013 | 06:55 PM
zman17's Avatar
zman17
Glad I could help. Problem solved, thread closed. Use die electric grease on all the plugs when you put her back together.
