2001 5.9 gas help
Old Apr 28, 2013 | 05:52 PM
bigdogdoge93's Avatar
bigdogdoge93
Default 2001 5.9 gas help
i have a 2001 5.9 gas half ton that i converted to 1 5-speed with a 93 nv4500 did tune up and oil change plus cleaned throtle body runs sluggish in morning until block gets to bout 180 then is fine do i need to advance timing or idk never really messed with efi motors before
Old Apr 28, 2013 | 05:58 PM
TiminSoCal's Avatar
TiminSoCal
Default Nooooo.....
Do not touch the distributor!
Timing is ECM controlled all you
will do is mess up fuel sync.
Old Apr 28, 2013 | 06:05 PM
gdstock's Avatar
gdstock
Got any CELs? Did you change out PCM?
Old Apr 28, 2013 | 09:50 PM
bigdogdoge93
still stock pcm and its had cel since fuel pump was replaced i did a cluster code chek to no avail but havnt hooked to the obd2 yet
Old Apr 28, 2013 | 09:59 PM
gdstock's Avatar
gdstock
Probably some codes related to PCM not seeing transmission solenoids and pressure sensor. Also may give a clue to the problem.
Old Apr 29, 2013 | 06:07 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1, what are the codes you are getting? Try checking them yourself. https://dodgeforum.com/forum/2nd-gen...code-list.html
