Front Sway Bar for my 4wd
Old Sep 21, 2005 | 01:13 PM
barneyrubble318's Avatar
barneyrubble318
Default Front Sway Bar for my 4wd
Anyone have a link for a sway bar for my truck? Should I stick with OEM? It is all bent, the links are bent, the bushings are shot. Summit doesn't have one for 4wd.
Thanks!
Jason
Old Sep 21, 2005 | 06:58 PM
richardmoore's Avatar
richardmoore
Default RE: Front Sway Bar for my 4wd
Try JCWhitney, and if worse comes to worse go to the dealer but make that you last resort. You could also try www.truckperformance.com they might have an aftermarket one.
Old Sep 21, 2005 | 07:01 PM
steve05ram360's Avatar
steve05ram360
I'd go to a wrecking yard for the bar, then go to a 4x4 shop for the bushing kit (urethane)... that would be your cheepest and best route in my opinion...
Old Sep 21, 2005 | 07:04 PM
richardmoore
Thats a good idea I didn't think about a junkyard.
Old Sep 22, 2005 | 03:48 PM
barneyrubble318
Anyone know the length of the links? Summit has the links and bushings, but i need the length to know which to order. The local dealer has the sway bar itself for $127.
Old Sep 22, 2005 | 07:37 PM
steve05ram360
wrecking yard...! can probably get everything you need for under $100 bux...
