AC harness
Old May 7, 2013 | 01:41 PM
byronpen's Avatar
byronpen
Default AC harness
ok The plug that engages your ac unit on the driver side of the motor, I cant find were to hook this up. I had it in bypass with a peace of wire, and now i can find the other end of the harness. Any one have a idea were to look
Old May 7, 2013 | 01:55 PM
Arde's Avatar
Arde
Plugs into the Freon line at the top of your compressor. Or as my wife would say, "it's where you laid it", she's irritating sometimes.
Old May 7, 2013 | 05:30 PM
zman17's Avatar
zman17
Retired Moderator - RIP
There are 2 connections on that side. One plugs into the high pressure switch in the ac line as Arde stated. And the other one connects to the wire running behind the pulley to the clutch. That plug is in between the VC and intake manifold under or near the #1 injector.
Old May 7, 2013 | 08:57 PM
gdstock's Avatar
gdstock
That one is on passenger side.
Has to be one of the ones on the compressor...One of those is AC clutch, the other is the high pressure cut out.
Old May 11, 2013 | 08:48 PM
byronpen's Avatar
byronpen
I had to replace the freon line. that plugs no longer there now what. how can i get it to work
Old May 11, 2013 | 08:55 PM
gdstock's Avatar
gdstock
Put the correct line on it. Have to have that sensor there.
