1996 Dodge Ram 1500 5.2L 4x4
Old May 12, 2013 | 01:00 AM
ChitownCustom's Avatar
ChitownCustom
Angry 1996 Dodge Ram 1500 5.2L 4x4
okay, I have a frustrating issue hear that may or maynot have been addressed. Bear with me....
My 1996 Dodge Ram 1500 used to stall out when coming to a stop. Following the advice that alot of you guys have given, I have changed the IAC sensor, crankshft position sensor, Ignition coil & done a tune up including spark plugs, distributor cap, rotor, pvc valve, air filter.
it seems to only stall when parking vehicle, at low speeds.
Someone tell me something I maybe missing.
Old May 12, 2013 | 07:25 AM
dhvaughan's Avatar
dhvaughan
if you keep a little foot pressure on the gas pedal does it stay running?
if so, consider replace throttle position sensor, TPS. about $40-50 new or maybe you got a buddy you could do a temp swap with.
welcome to DF.
Old May 12, 2013 | 03:35 PM
zman17's Avatar
zman17
Retired Moderator - RIP
What brand sensors did you buy? And was the negative battery cable disconnected while changing them?
Old May 12, 2013 | 08:22 PM
ChitownCustom
__________________
I got the crankshaft sensor from autozone so it was a DURALST. I dont remember about the others.
And NO the negative cable was not disconnected.
Old May 12, 2013 | 08:24 PM
ChitownCustom
welcome to DF.
No sometimes it will still cut-off.
